Stall not locking up
Old 02-21-2007, 04:30 PM
Cop Car's Avatar
Default Stall not locking up
99% sure its not the new Yank stall. it will intermittantly lockup and sometimes not lock up, along with not going into OD or downshifting at stoplights. i just want to make sure that replacing the lockup solinoid will solve my lockup problems.. im going to drive 2,000 or so miles here in a month and id like to have a lockup.
Old 02-21-2007, 04:43 PM
Yank's Avatar
Did you recheck the trans oil level?
Old 02-21-2007, 04:44 PM
LS1Tech Sponsor
performabuilt's Avatar
have you scanned for codes yet ?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 02-21-2007, 04:45 PM
Cop Car's Avatar
yes, the level is fine, i literaly just checked it 10 minutes ago.
Old 02-21-2007, 04:46 PM
Cop Car's Avatar
no i havent scanned it for codes..
the trans has a transgo shift kit.. and has about 130k on it.. B&M trans cooler.. ran through radiator then cooler.
Old 02-21-2007, 05:16 PM
LS1Tech Sponsor
I would scan for codes that type behavior should set one
__________________
Call 888-744-6542
Old 02-22-2007, 04:03 PM
Frost's Avatar
Does the car have an aftermarket cam? If so, have your misfire tables been set high?
Old 02-22-2007, 04:11 PM
import slayer's Avatar
would that cause it to not lock up because my converter does not lock up either and Because of my big cam it will throw a misfire code sometimes
Old 02-23-2007, 12:13 AM
02 BLK WS6's Avatar
I would go ahead and replace the tranny wiring harness along with the TCC solenoid.
Old 02-23-2007, 07:14 AM
Frost's Avatar
Yeah it's a given for a cammed stalled auto. Raise all of your part/medium throttle misfires tables to the ceiling and re-discover regular intended locked up driving.
Old 02-23-2007, 03:26 PM
Pathological Modifier
Ryan K's Avatar
Go to the PCM section BEFORE you start replacing components, I did a writeup on this along time ago. And you don't have to have a aftermarket cam to make this happen...
Ryan K.
Old 02-23-2007, 03:31 PM
Ryan K's Avatar
https://ls1tech.com/forums/pcm-diagnostics-tuning/162767-i-just-replaced-my-torque-converter-now-unlocks-randomly-fix.html
