Energy Suspension Tranny Mount?
Old 03-05-2007, 10:06 AM
UCABlackChevy's Avatar
Default Energy Suspension Tranny Mount?
Alright, I did a search and could not get anything conclusive out of it. My tranny mount is split and I was wanting opinions on the Energy Suspension mount.
As of now the car is stock, but that won't last too long. Future plans are probably stall, cam, maybe nitrous.....primarily street car with some time at the strip. If there are any others that are better let me know.
Old 03-05-2007, 10:18 AM
GT Griller's Avatar
Stock mount never broke on me...but when i pulled the tranny to rebuild i switched to energy suspension mount and wouldnt u know it 3 weeks later that bitch broke.
Old 03-05-2007, 10:23 AM
bluehawk2's Avatar
my energy mount vibrates like a ****
Old 03-07-2007, 01:57 PM
Now that I have seen a picture of a torque arm mount I think it may be that, when I was changing my fuel filter the other day I glanced up there and it looked like the torque arm mount was broke. Should I go with a stock one or with a poly one if it is indeed the torque arm mount?
Old 03-07-2007, 02:33 PM
Trunion King
bene's Avatar
If you don't mind vibrations in your car get the ES bushings. Rubber ones absorb ALOT of those annoying vibrations. I'd stick w/ stock ones since the car is mainly use on the street.
Old 03-07-2007, 02:55 PM
GregWS6&z28's Avatar
1LE mount is like stock but stronger I believe. it's kinda expensive I think
Old 03-07-2007, 03:18 PM
Does anyone know how to change out the torque arm mount and would it require readjusting the pinion angle after the mount replacement?
Old 03-07-2007, 05:57 PM
BlackHawk T/A's Avatar
There is only one mount for our cars.
Myself and some others are re-installing our stock mounts after finding the vibration with the ES/Prothane mounts to be too much. Though people make the ES vibrations sound worse than my Prothane.
I only changed it at the time the transmission went in for preventative measures, but I never broke my stock one. I'll swap them back, and will hold onto the Prothane in case I need it. A lot of automatic cars don't have problems breaking the mount but there are always some who will, but its in the minority rather than the majority like the M6 guys.
Old 03-08-2007, 02:32 AM
WS6 Rampage's Avatar
Location: The dirty taint of the country. ...Los Angeles
I just got my Prothane: Motion Control tranny mount in today.... They come highly recomended and I haven't heard anyone say anything negative about them yet. Might wanna look into those too.
Old 03-08-2007, 11:36 AM
01_ram-air's Avatar
1.49-1.52 60' times =
I now have the energy suspension mount and haven't had any issues. For some reason I don't have any pictures of it though.
Old 03-09-2007, 08:20 AM
I'm gonna try to get under the car today to take some pics of the torque arm mount and transmission mount to see if I can find out which one is causing my troubles......could it also be my exhaust? I know at stoplights the cat-back rattles like a s.o.b. I forgot to mention the problem is I feel a thumping of the floorboard when I get on it from a mild thumping at 1/4 throttle to moderate thumping at 1/2 to WOT.
Last edited by UCABlackChevy; 03-09-2007 at 08:22 AM. Reason: left out the problem
