ls1 to th350
Old 03-08-2007, 12:09 PM
v8m3's Avatar
Default ls1 to th350
do they do a conversion plate for this as my bolt holes dont line up any help appreciated
thanks wayne
Old 03-08-2007, 03:35 PM
BTLFEDSS's Avatar
It will line but not all of the i beleive one bell housing bolt hole goes to nothing on my TH400.Been a while since i was under the car though
BTLFEDSS
Old 03-08-2007, 07:21 PM
jay_lt4's Avatar
yup should bolt up just fine, th350 in my 6.0L s-10(same as a ls1)
Old 03-08-2007, 08:00 PM
mooreperformance's Avatar
depends on the bolt pattern your th350 has. If it's for small block cheby than all but two bolts should line up.
Old 03-09-2007, 12:21 AM
v8m3's Avatar
Default trans
what tc and flex plate should i use trans is out of a sbc but flex plate is too small will an lt1 auto go onto my ls1 with no messing ? we dont have the part shops in england like you do there
wayne
Old 03-09-2007, 08:01 AM
JB2wheeler's Avatar
There is some sort of spacer that needs to go in there somewhere. Maybe between the flexplate and the TC or...? Later today I will see if I can search for exactly what that is. JB
Old 03-09-2007, 01:13 PM
jay_lt4's Avatar
this should be all the info you need:
https://ls1tech.com/forums/automatic-transmission/639693-ls1-style-engines-old-style-trans-th350-400-2004r-700r4-4l60e.html
