4L60E build
4L60E build
Ok so i was thinking about building my transmission my self.. not sure if these are all the parts needed but i'm looking for some thing that can handle about 500 hp..
red eagle power pack (clutches and bands)
.500 boost valve
13 vane pump rotor
4140 hardened pump rings
sonnax wide open throttle valve
beast sun shell
kevlar band
billet servo
If there is any thing else that is needed plase let me know or if there are an special tools that i need.. thank you
.500 boost valve
13 vane pump rotor
beast sun shell
kevlar band
billet servo
.500 boost valve
13 vane pump rotor
beast sun shell
kevlar band
billet servo
.500 boost valve
13 vane pump rotor
beast sun shell
kevlar band
billet servo
LS1Tech Sponsor
Lots of time and patience , And some tools , a compresser for the drums , and a good pair of flat snap ring pliers , ring sizers if you plan on replacing the teflon sealing rings ,
seal installer tool . are a few . And the understanding that doing it right and paying retail for parts you may end up with as much or more in it that just buying a unit by the time your done, But if you need help in the process or advice just holler,
__________________
so far i've found all those parts for about $372... But i was also wondering if there is a kit that i could buy with most of this or better parts that can handle about 500 hp for around the same price or cheaper.. and were would i go to get those tools needed for this..
