Lost 4th gear in 4L60E, what to look at?
Old 03-21-2007, 12:45 PM
Primered's Avatar
Default Lost 4th gear in 4L60E, what to look at?
Bought from a buddy Was working fine yesterday morning then left to go home and wouldn't even go into 4th at all.
Here's the build sheet on it when he had it built which was a few years ago and the thing has less than 5K miles on it!
transgo shift kit hd-2
wide band hd kevlar
banner kit master/with koleen steels/ hd red clutches
bushing kit
bearing kit
capsul for relase on servo
super servo 1-2 beast sun shell with reaction shaft 4l60e bearing input sprag 4l60e
pinless accumulator piston
z-pack 3-4
pwm solenoid
1-2 shift solenoids
2-3 shift solenoids
3-2 shift solenoid wiring harness/ l/u solenoid
5 pinion planetary set (cryo'd)
cryo'd input and output shaft
Old 03-21-2007, 01:07 PM
LS1Tech Sponsor
performabuilt's Avatar
First I would scan for codes, Then if possibile run scanner or tuner and look at data stream while driving observe if 4th gear is being comanded.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-28-2007, 03:58 PM
Primered's Avatar
All normal, what else?
Thanks
Old 03-28-2007, 04:06 PM
Dan
Dan's Avatar
Do you have reverse? I recently lost "overdrive" & reverse, It was the rear planitary gears
Old 03-28-2007, 04:11 PM
Primered's Avatar
Yes, it's still working.
Old 03-30-2007, 06:56 PM
Primered's Avatar
TTT, Anyone?
Old 03-30-2007, 08:37 PM
LS1Tech Sponsor
So you did scan the data stream and it is comanding the fourth gear shift ?You can see it change from 3rd to 4th on the display?
__________________
Call 888-744-6542
Old 04-01-2007, 01:04 PM
FaSS Blac's Avatar
Check your 2-4 servo assy on the side of the case. I tried to use this super hipo better than sex 2-4 servo kit a few years back and got butkis for fourth on the highway. Installed it at my friend's moms house in West Patterson, Had to drive from exit 16W to exit 7 with NO 4th GEAR!!!!!!!!! Tacking 3,000 rpm on the turnpike was no fun!!!! Got my stock servo out, lowered y-pipe, trans, installed STOCK 2-4 SERVO. Like magic, got 4th gear. If you like filing servo pins or using experimental parts, DON'T USE THE STOCK SERVO. If you want fourth gear, USE THE STOCK CORVETTE TYPE SERVO, which I think is what's stock in LS1 cars.
Old 04-01-2007, 02:34 PM
Predator T/A's Avatar
if your second gear is working then i would think that the 4th servo may be leaking 2nd uses the band alsoin 4th the 3rd clutches are on also so if you have 2ndd 3rd i may say that the 4th servo piston is leaking...the 3-4 shift isnt really controlled electronically so i doubt its a electric problem your 3-4 sheduling valve could be stuch also
Old 04-01-2007, 03:36 PM
LS1Tech Sponsor
Actually 4th gear as all gears in a 4l60e is controlled electronically
1= both solienods on
2=1-2 solenoid off and 2-3 solenoid on
3=both solenoids off
4=1-2 solenoid on and 2-3 solenoid off
Its gets a little confusing for so people because there are only the 1-2 and 2-3 solenoid which would lead one to beleavie that they do not control fourth , Thats why I prefer shift solenoid A (1-2 solenoid) shift solenoid B (2-3 solenoid)
each gear is created based on the combination of and on and off of these two solenoids, Two solenoids do make 4 gears because there are four combinations .
Though a hydralic issue is always possible with the 4th servo since it was working fine before again I would check and see what gear is being comanded in the data stream as I mentioned before first.
__________________
Call 888-744-6542
Old 01-28-2019, 01:49 PM
sergio00898's Avatar
Default corvette servo 4l60
I did replacement on mines but I didn't have 4th gear also I took it apart and one thing I noticed is the third plate is jammed in there so I cant remove it completely is there any way to remove it?
Old 01-28-2019, 02:39 PM
MaroonMonsterLS1's Avatar
Received 1,212 Likes on 778 Posts
People seriously need to start looking at the post dates for threads.
Start a new thread and post pictures of your issues.
Otherwise...get the torch out...I bet you can manage to get it apart that way
Quick Reply: Lost 4th gear in 4L60E, what to look at?
