Any overdrive tranny out there that handles 1200hp?
Old 03-22-2007, 08:34 PM
ttcamaro's Avatar
Default Any overdrive tranny out there that handles 1200hp?
Im looking for an auto that will handle 1200+hp that has an overdrive. Does this exist? Not really looking to get into gear vendors. LT1 camaro
thanks
Old 03-22-2007, 08:46 PM
=Tac='s Avatar
What would you want OD for? I doubt you'd get THAT much better gas mileage with OD and 1200horses
Old 03-22-2007, 08:52 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Question
A built Turbo 400 with a Gear Vendors Unit. Why not a GV Unit.???
Old 03-22-2007, 09:00 PM
TwnTrboCE's Avatar
Well built 4L80E. See sig. Will be putting around 1500 thru mine this season.
Old 03-22-2007, 09:13 PM
LS1Tech Sponsor
performabuilt's Avatar
While we presently do not carry them. I would have to agree that a 4L80E is your best bet short of a gear vendors and a 400
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-22-2007, 10:31 PM
ttcamaro's Avatar
thanks for the replys
Where did you get your tranny? Is there a kit for the swap?
Old 03-23-2007, 12:10 AM
FLT
FLT's Avatar
The pretty blue 5000lb. truck on top of our web page pumps 1200hp through our extreme duty 4L80E, that's correct I did say truck!! You might want to check us out.
Old 03-23-2007, 12:57 AM
maddboost's Avatar
thanks
Cant go wrong with a FLT Level 5 4L80E. You will also need a new transmission crossmember which BMR sells.
Old 03-23-2007, 06:21 AM
beardWS6's Avatar
how effecient is the 4L80E of robbing RWHP. My A4 eats alot of it up!
Old 03-23-2007, 09:12 AM
ttcamaro's Avatar
Chuck what power level would you say this tranny would be good to? If i decided to step up to 1700hp range i wanna know the tranny will be good.
thanks
Old 03-23-2007, 09:40 AM
Custm2500's #1 Fan
silver-mod-o's Avatar
FLT for sure Parish's truck has put theirs through the paces with zero headaches...
Old 03-23-2007, 07:14 PM
NA$TY-TA's Avatar
Hes running a Rossler built 4L80E... with a Rossler Transbrake....
Old 03-23-2007, 07:55 PM
DeltaT's Avatar
Once you super-build a TH400 and add a GV OD unit, you are in the ballpark of a topend 4L80E build including the electronics. Plus the advantage of the programmability - my 80E is very mellow around town until it hits the 50% TPS mark, then it completely changes personality into neck-snapping shifts.
It does weigh about 75lbs more than the 60E, and even more with a deep pan, but it will get the job done into the 4-digit HP area. Hughes built mine for 1000HP.
Jim
Old 03-23-2007, 08:18 PM
NA$TY-TA's Avatar
Jim
what did they charge for one built to handle that??
Old 03-23-2007, 08:31 PM
beardWS6's Avatar
Yes, what was the cost.
Old 03-24-2007, 07:43 PM
DeltaT's Avatar
Total was $4300 plus a core charge of $800. At that time I could not find a good core but now they are about $300-400 locally so I would have saved a few hundred after shipping.
That included:
Built tranny
Converter
TCI T-Com computer and harness
Mech. speedo drive
Shipping to NorCal
Buy it from a Hughes Dealer and the price is better than what Hughes will quote you directly. I got mine through Sallee Chevrolet (now Gilbert Chev)
When I bought it there were only a couple sources for high HP 80E's. Now there are more but many I don't know their quality & reliability.
Jim
Old 03-24-2007, 08:52 PM
engineermike's Avatar
1200 hp will push you to somewhere around 160 mph in the quarter. Depending on engine max rpm, tire height, and converter slip, your rear gears will end up pretty tall. I question the need for OD.
For example, I'm running 146 mph in the quarter. With a 26" tire, my rpm in the trap is 6400 (peak hp is 5700). I'm geared about right, or slightly short. I'm running 3.00/1 in the rear, which is very livable on the street. If I were pulling 160 in the quarter, I'd need a 2.73, which is even better.
Mike
Old 03-24-2007, 08:56 PM
LS1Tech Sponsor
Actually a good point with that much power and torque you could run 273s or if available even 256 gears and have that same highway rpm as lower gears with the overdrive and though back in the early 80s when they used those gears with 305 engines it sucked but with 1200 plus HP you should still be a monster across the board
__________________
Call 888-744-6542
Old 03-24-2007, 11:04 PM
TwnTrboCE's Avatar
Mike
I trap 170mph and run a 28" tire and a 3.50 gear. Looking to go near 180 on a 30" tire this season. But that has nothing to do with the fact that I have overdrive. It has to do with the fact that I plan on running that, then driving it 300+ miles to the next track and doing it again.
Being able to put it in OD and having the converter lockup. Makes for a nice highway drive.
BTW, I don't use OD at the track. But I do lock the converter.
Old 03-24-2007, 11:20 PM
ChucksZ06's Avatar
Default TH400 won't shift to reverse
Worked fine when parked for winter...fluid level seems ok. Forward gears work fine... now it will not move at all in reverse...tranny does have some runs on it but not a lot...it is a b&m rebuild. Any thoughts appreciated. Chuck
