Adjustment Questions.
Old 03-23-2007, 09:03 AM
DeadLifter's Avatar
Default Adjustment Questions.
I'm new to the 4l60e I was wonderin if there's any band adjustments or anything to do while changing fluid.
And is the fluid/filter change pretty straight up like any other tranny?
Old 03-24-2007, 10:43 AM
DeadLifter's Avatar
Anybody?
Old 03-24-2007, 12:55 PM
LS1Tech Sponsor
performabuilt's Avatar
There are no ajustments normally needed during a service of a 4l60e . I would sugest that provided the seal is soft and the filter fits tight that you do not attempt to change the gromet seal thats in the pump for the filter , Is a major pain under the car and should be fine
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-24-2007, 01:28 PM
DeadLifter's Avatar
I read about that seal on here. I'll check it out and see how it goes, if it doesn't look like it's worth changin I won't mess with it.
Thanks a lot for the help.
