Installing New Tranny?
I'm having my messed up tranmission taken out and installing the level 2 performabuilt transmission.(Can't Wait)..Just wondering what kind of fluid would be best and how much of it should i buy..also is there a break in period for the new trans...
anyways thanks for any help
LS1Tech Sponsor
put about 1 quart in converter, install trans, put six quarts in trans , start in neutral wheels raised, add till full, run car through gears several times with wheels raised, turn off car, check for leaks and over all you have done, lower car, start car in park recheck and top off fuild if needed,drive car normally for rest of day, Next morning start car,run till warm, check and top off fluild. Thats it, And any fuild that meets or exceeds dexron mercron requirments is fine.
__________________
