Which Tranny cooler?
which transmission cooler do you recomend for an 01 SS CAMARO A4, what is torque management? Thanks Danielle
tranny cooler
Im using a B+M Race cooler it is mounted where the front bumper used to be. I ran custom hydraulic lines in place of the old tranny cooler lines after the headers burned a hole in them.
Plate type coolers like the B&M supercooler are a good choice. Size needed depends upon the converter, your driving style, and weather.
Torque management is programing in the PCM which mainly pulls timing at the instance of the shift in order to reduce the amount of torque being exerted on the transmission while it is trying to shift.
