Torque Converter Code P0757
Torque Converter Code P0757 - Installed a new torque converter, higher stall, and now get check engine light and lose power. Can reset computer but comes back at slow speeds.
C5-Corvette 4l60E Transmission, Something to do with 3/4 shifting or slippage. I understand that it can be edited out with HPTuners.
How do I edit/remove this code in HPTuners.
Thanks,
Thanks,
This is a common code once you've installed a hight stall torque converter. Go to engine diag. and then DTCs and deselect the codes you want off.
