P0758b trans not shifting after car ran hot
Old 04-04-2007, 04:28 PM
2000badbird's Avatar
Default P0758b trans not shifting after car ran hot
i tried a search its not working as usual i need some help from the tranny guru's i have a 2000 formula with a 4l60e stock stall the car ran hot on me today well i have taken care of that issue now the trans fells like its in neutral and setting P0758b code. the trans fluid smells ok not burnt and fluid color is good nice and pinkish red like its suppose to be i baffled did i burn up my tranny or did maybe the fluid temp hot to the point that the solenoid is not letting the trans shift. somebody help me
Old 04-04-2007, 04:37 PM
LS1Tech Sponsor
performabuilt's Avatar
I answered you in PM but 758 is and electrical fault code for shift solenoid B when you say neutral are you sure you dont means it feels like its takes off in 3rd, Also how does reverse act
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-04-2007, 04:54 PM
reverse works fine and it takes off in first then shifts to second then feels like it goes into neutral or some type of a stall of second instead of shifting to third im prayin in its a simple as solenoid
Old 04-04-2007, 04:57 PM
LS1Tech Sponsor
Well I would drop the pan with the intention of changing the B solenoid , But while I was in there I would abserve whats in the pan and post that up , With any luck you have a bad shift solenoid but a failed 3-4 clutch is also a possibility ,
__________________
Call 888-744-6542
Old 04-04-2007, 05:13 PM
well im gonna pull the pan see what happens if its okay i will replace the solenoid. i need to a picture of which solenoid it is im not sure there is a few in there
Old 04-05-2007, 01:11 AM
LS1Tech Sponsor
pm your email and ill send it to you
__________________
Call 888-744-6542
Old 04-05-2007, 09:17 AM
pm sent. okay so inside the pan looks okay no more debris than naturaly be there some but not much. pretty much like the first time you pull a pan off of a perfectly working trans to service it. i didnt do a good job describing the symptoms. it feels fine in reverse and first then it shifts to second second is fine then it just dont shift just stays in second i drove it agian just before i pulled the pan last nite so maybe the better explaination could be more helpful cause with it acting like that and what it looks like i believe it just may be the solenoid and nothing else im going to the dealer to get the solenoid in a few minutes
Old 04-05-2007, 09:40 AM
LS1Tech Sponsor
My honest suggestion is no more expensive than they are is to replace both of the shift solenoids as a set ,
__________________
Call 888-744-6542
Old 04-05-2007, 11:12 AM
yeah um from what they told me there is a 1-2, 2-3, 3-4, and a 3-2, should i replace all or just 2-3, and 3-2,
Old 04-05-2007, 11:14 AM
LS1Tech Sponsor
No just SHIFT SOLENOID A(1-2) and SHIFT SOLENOID B(2-3)
__________________
Call 888-744-6542
Old 04-05-2007, 11:19 AM
okay awesome i thank you for taking the time to answer my questions i will let you know the outcome goin to pick those up now look pretty easy to change out just a clip. im an experienced tech thats a newb with working on auto trans other than general maintence and removal and replacement
Old 04-05-2007, 11:22 AM
LS1Tech Sponsor
should be a peice of cake . One of them has a spring loaded valve behind it remove slowly
__________________
Call 888-744-6542
Old 04-05-2007, 12:20 PM
okay so i changed to solenoids it was simple gonna go button it up take it for a ride thanks performabuilt you guys got my approval if i do end up needing a trans ile know who to call
Old 04-05-2007, 01:41 PM
well it was the solenoids i put it back together and it shifts like new no issues no codes no slipping.
+100 for performabuilt i dont own any of there products yet but he still pointed me in the right direction i believe that if i have any trans needs of know anybody who does im gonna refer them to performabuilt.
Old 04-05-2007, 02:23 PM
LS1Tech Sponsor
Glad it worked out for you and thanks and your welcome all at the same time
__________________
Call 888-744-6542
