Converter noises
Old 04-07-2007, 01:47 PM
1hotls1's Avatar
Default Converter noises
Should a new converter make any noise if you shake it around? I just noticed that one we are using will rattle a good bit if you shake it.
Old 04-07-2007, 03:44 PM
LS1Tech Sponsor
performabuilt's Avatar
The internals of the converter are centered on the pump stator , So when the converter is not on the pump it will rattle
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-07-2007, 08:08 PM
FLT
FLT's Avatar
I would suggest putting a 1/2qt to a quart of dexron fluid in that tc before the installation. It is never a good idea to dry fire a torque converter. Good luck with the new stall. Vince
Old 04-09-2007, 12:02 PM
1hotls1's Avatar
Thanks for the advice. I put about a quart in it and no problems.
