Trans cooler hookup questions
Old 04-08-2007, 08:02 PM
sp00rkz's Avatar
Default Trans cooler hookup questions
So, if you had an aftermarket trans cooler, would you hooke it up after your stock cooler or would you bypass your stock cooler? Why?
Old 04-08-2007, 08:31 PM
smoknta's Avatar
I have an aftermarket cooler and I ran it in series with my stocker. Run it through the stocker then through the aftermarket. The stocker will help pull heat of the fluid, especially at idle. My fluid stays pretty constant at 160 unless I hot lap or sitting in traffic.
Old 04-08-2007, 10:23 PM
Custm2500's #1 Fan
silver-mod-o's Avatar
run it with your stocker in place... my setups a little different than that but it keeps it at 150 or less no matter what I do.
