Vroom Vroom, but no GO GO
Old 04-17-2007, 10:52 PM
REBORN Z28's Avatar
Default Vroom Vroom, but no GO GO
I just put the trans back into my 94 Z28, and Im having problems. Its an automatic by the way. When I put the converter in the trans I rocked it back and forth so it seemed to be where it should be. There was fluid inside it, maybe a quart, and I put about six quarts of full synthetic down the tube. Thats about a quart less than what I was told to put in, but when I check the level cold its showing the level to be high. About two thirds up the hash line on the stick.Whats happening is when I step on the gas, it doesnt accelerate for ****. this happens in forward reverse. Any ideas?
Old 04-18-2007, 06:19 AM
FLT
FLT's Avatar
Sounds like you broke the pump. Pull a cooler line off and see if it is pumping.
Old 04-18-2007, 05:02 PM
BlackHawk T/A's Avatar
An empty transmission and converter will need a lot more than 6 quarts...it should have sucked that down pretty quick unless like Vince stated, the pump is broken.
Old 04-18-2007, 07:52 PM
daniel6718's Avatar
an empty tranny and converter will hold 12 corts...your prolly getting a reading from the extra fluid stuck in the dipstick tube...
also the linkage is adjustable...and the converter should have slid into the tranny 3 times...in further then further...bolt the trany up and the converter should ahve been about 1/4 inch from the flywheel...
Old 04-18-2007, 10:37 PM
2000SLPZ28's Avatar
your suppose to check the fluid when the car is in park and at full temp.
