This is whats needed for the 4l60e to 4l80e swap!
Old 06-13-2007, 07:09 AM
LS1rulz's Avatar
My rear line fitting on the tranny is long, and sticks inside the tranny. It's a quick connect. My builder says it NEEDS that length sticking inside. I think I'm gonna grab the QC fittings and go from hard line to hose.
Old 06-23-2007, 10:13 AM
fastlt1's Avatar
So has any done the swap in a LT1 A4 car?
1. Will the PCM work the trans?
2. What convertor do you use?
What would be different in the write up?
Old 06-25-2007, 09:30 AM
Z'mnypit's Avatar
Originally Posted by Superman09
Great write-up! Ill be doing this conversion once my 4l60-e starts slipping. My only question is the Speartech harness, i looked on their site and couldnt find what i need, can anyone link me? Thanks!
http://speed-eng.com/store/product_i...oducts_id=7780
Old 07-02-2007, 01:17 PM
BlownShovel's Avatar
Originally Posted by sdimess84
im doing a 4l80e into a 96 s10 truck with a 5.3 motor
I have the 30 4l80e installed (partially) into my 95 truck(was 4l60e).
Anyone know what U joint would convert a small shaft (95) to the 03 Yoke? I picked up one joint based on a spicer catalog and thave the diameters correct but nee the yoke side to be wider. Basically a Cross U-ujoint is necessary.
EDIT: Here are the specs
what I need:
Yoke Side uses 1.188 cup diameter and 4.124 width
Driveshaft side uses 1.0640 cup diameter and 3.6350 width
The stock install utilized exterior spring clips to hold the joint in place
Thanks
Old 07-30-2007, 10:59 AM
Moderator
LIL SS's Avatar
Originally Posted by 95ttoplt1
Does anyone know if it is possible to copy the tranny part of the .bin file from the LSX truck bin to a OBD1 LT1 car .bin?
From what I "thought" I understood, HPtuners allows you to reflash a 99-02 F-body with an A4 OS if you have a M6 (or newer 02 OS if you have a 99-01). Once that is done (or you already have an A4) you can copy the trans settings from a 4L80E equiped vehicle in to your tune. How ever, I have tried this in my 1963 LS1/4L80E swap and I can only get reverse and one forward gear (not sure what gear, feel like 2nd though). I tried data loging the gear but it shows 2nd all the time, even in reverse, park and neutral.
I was just advised by e-mail from HPtuners that they do have to do some changes.
BTW, I am using a very early 4L80E. This one required a different internal wiring harness one other internal device (think it was a manifold pressure sensor). One bolt hole does not line up.
A 4L80E converter is a different bolt pattern from a 4L60E. So even if you use a spacer, you need to have a converter with a 4L60E bolt pattern and a 4L80E pump end. I'm using a 4L80E converter along with a 4L80E flexplate.
Old 08-02-2007, 01:54 PM
Z'mnypit's Avatar
Correct, just because you flash the PCM with an A4 .bin doesnt mean its going to work. HPtuners modifies the 4l80e os somehow to your os. Its not something we can do.
I do have one question though. What PCM connector and pin location do you wire the front VSS to? Thanks in advance.
22 and 23 I believe it was on the red... Dont hold me to that it has been awhile since I did it.
Old 08-02-2007, 03:17 PM
DROPTOPLS1's Avatar
This is from cablebandit's write up.
4l60e to 4l80e harness......speartech or speed-engineering. When you hook up the ISS wires to the pcm, they go to pins 22-23 of the red connector, if you gently take off that red plastic (the part that makes it the RED connecter) the pins slide in VERY easily and you can see how they lock/unlock. The instructions with the harness tell you what wires go wherel....very easy and idiot proof...5 minute deal.
Old 08-03-2007, 01:56 AM
Moderator
LIL SS's Avatar
What's the front VSS used for? It seems to work fine (all 4 gears) afte rthe HPtuners modified OS but would like to know if I can benifit from having it hooked up.
Old 08-05-2007, 11:30 AM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
whats the weight difference between the 4l80e and th400?
Old 08-08-2007, 01:01 PM
Moderator
LIL SS's Avatar
My 4L80E was 270 on the shipping pallet. That might help you.
I'm really diging the 4L80E in my truck (63 P/U). I'm running a stock verter with 3.73's and a 275/50/15 BFG DR. Given it's not fully tuned yet, it gets out of the hole with out spining tires. I shifted it yesterday for the first time at 5900 and it chirped the tires real good in second. It was down 10-15* timing due to TQ management and I still need to dial the AFR a bit, But I think the tall first will help me out of the hole when I start playing with the bottle.
Old 08-14-2007, 10:11 AM
streetfytr68's Avatar
Front VSS communicates converter speed. Rear is tailshaft speed which, combined with final drive ratio and tire diameter, is used to calculate wheel speed.
Another tip: If you are running a stand alone trans controller such as TCI, you can re-flag your ECU as M6 to prevent SES codes generated by the disconnected stock trans harness. The TCI unit comes with it's own harness. You will splice RPM, TPS, and speedo.
Old 08-21-2007, 04:14 PM
  #32
N4cer's Avatar
Going M6 to 4L80e, I had LT1wiring.net send me the parts. One is a harness that fits the auto, and wires into the PCM. The other is your new VSS connector. Something like $51 shipped. Can't beat it.
Old 11-06-2007, 11:01 AM
  #33
Z'mnypit's Avatar
Originally Posted by fastlt1
How are people with 99+ cars gettting the speedo to work?
Theres a harness you have to wire into the PCM so that it sees the 2nd VSS. HPTuners/EFI Live also has to modify your .bin or etc to work with the 4l80e.
Old 11-06-2007, 11:32 PM
  #34
Stangkilr's Avatar
I just used my m6 connector and plugged it into the rear sensor.
Old 01-28-2008, 06:03 PM
  #35
Texas_WS6's Avatar
What kind of rwhp can a 4L80E handle? I am looking for something that will handle 900rwhp. who makes the best one?
Old 01-28-2008, 07:02 PM
  #36
Stangkilr's Avatar
900hp shouldnt be a problem. Contact Finish Line Transmissions on here.
Old 01-28-2008, 07:54 PM
  #37
T-Bones Goat's Avatar
I got mine from RPM Transmissions that is capable of 1200rwhp. http://www.rpmtransmissions.com/
Old 01-31-2008, 02:50 AM
  #38
LTtorque's Avatar
Default never addressed?
I was reading this thread since I am really thinking about the 4L80E swap and needed to know what I need to do and what all is involved with it. This thread is full of everything I need except I never saw the LT-1 questions answered? I will be putting the 80E in my 96 LT-1 if I decide to go with the 80E(not sure yet over a T-56 cause I'm doing circuit racing and not sure what is better yet?) What is different in the write up for a LT-1 car? If anyone knows please help..
Old 01-31-2008, 02:53 AM
  #39
LTtorque's Avatar
Sorry reposted to subscribe
Old 02-01-2008, 09:09 AM
  #40
Z'mnypit's Avatar
Other then the PCM side of things it shouldnt be much different. If you went with a manual valve bobdy then you wouldnt even have to worry about the PCM. Everything else should be the same.
Quick Reply: This is whats needed for the 4l60e to 4l80e swap!
