4l60 from 94Z into 93Z 700r4 car??
Old 04-20-2007, 06:19 PM
94strokedz's Avatar
Default 4l60 from 94Z into 93Z 700r4 car??
What all would I have to do to put the trans from my 94 Z28 into my wifes 93 Z28? I have a perfectly strong 4l60e trans in my car that her car will never kill, so I would like to swap it with her 700r4 if possible. My car is going to recieve a level 3 performabuilt invincible trans, and hers will get a level 2 performabuilt if I can not make the swap. Thanks for any info, Nick.
Old 04-20-2007, 06:35 PM
LS1Tech Sponsor
performabuilt's Avatar
Unfortunalty that swap is probably not practical you would have to buy and aftemarket controller to run the 4L60E in the 93 or change out the PCM and wiring harness from a 94 into the 93
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-20-2007, 07:26 PM
blown94's Avatar
im doing something along these lines right now. Theres a thread in LT1 section about putting a '95 engine into a '93. Im dropping a '94 drivetrain into a '93 tomorrow. I think I have all the wiring figured out but I have the engine harness from the donor setup. You need to swap the engine harness and move a few wires around to make it work. Depends how serious you are about it. Im dropping the whole drivetrain, but I dont know if Id do it just to put a tranny in. You will also need the PCM as stated already because the '93 has a burnable chip and in '94 and later the PCM is flashable.
