Gear selector in 96 A4 trans am
Old 04-23-2007, 08:26 PM
enyaw_96's Avatar
Default Gear selector in 96 A4 trans am
My first 4th gen A4................the selector only has D 3 2 what is needed to shift into first? Can i just mod the console or do i need a diffrent console and shifter...thanks
Old 04-24-2007, 12:34 PM
steady01's Avatar
Default Bump
Bump Guys Need Help
Old 04-24-2007, 01:25 PM
LS1Tech Sponsor
performabuilt's Avatar
My understanding is theres a plastic stop there to keep it from going back but if you remove it even though the selector dosent say 1st it will go there
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-25-2007, 05:50 PM
koolaid_kid's Avatar
Correct. Remove the console. Shift down to 2nd gear. You will see the plastic stop that it hits. Remove. I used a small hacksaw. (You can probably replace the gear indicator plastic if you wish.) I did not, but I still have 1st gear when/if I want it.
Old 04-26-2007, 06:47 PM
enyaw_96's Avatar
Thanks guys............
