TH350 leaking from vent
Old 05-06-2007, 03:44 AM
matt94z's Avatar
Default TH350 leaking from vent
I was putting my motor in tonight and I noticed that there was fluid stain from the vent caused by a leak. I thought that I had a small pan leak before that and swapped gaskets. What would cause this problem?
Old 05-06-2007, 07:56 AM
WE TODD DID's Avatar
If it isn't way over full, heat is generally the cause of that. Most likely being the converter.
Old 05-06-2007, 10:16 AM
matt94z's Avatar
I've got a 3400 Edge, do you think a bigger cooler might help? Other than that I have no issues. I've got a deeper pan already also...
Old 05-06-2007, 10:45 AM
FLT
FLT's Avatar
If it is just a stain, you probably got it hot at one time or another. It is not uncommon to have a film or a stain like you have described near a vent. I probably would not worry about it. A cooler with a stall is always a good idea and the bigger the better if you have room. Vince
Old 05-06-2007, 11:41 AM
matt94z's Avatar
I have lots of room, I took out my ac condensor. What kind of cooler would you guys recommend? Where to buy?
Quick Reply: TH350 leaking from vent
