i am putting in a 2000 LS1 in to my 95 TA. i am keeping my tranny. what will i have to do to it to make it work. i tryed a search and i found some infor about spacer and bolts?? any help wpuld be great!
Well your will need a spacer/adapter for the converter as mentioned, Also if you use the LS1 pcm you will need to change the trans internal electronics to match the PCM being used.
i sent my harness to spear tech. he said he will be adding the auto trans stuff to the wire harness. is that what you are talking about? and do you guys sell the spacer/adapter??
No we do not sell the spacer adapter, I think yank may.
And if you sent the wiring to them and they know wha your doing Im sure they will set it up correctly
