Whats a streetable th400?
Old 05-13-2007, 01:50 PM
nahasapeemapetalon's Avatar
Default Whats a streetable th400?
I have questions regarding streetability of a good racing th400. For those who drive theres on highway trips and daily driver in the summer what kinda stall are you running? I heard if u have a transbrake your need a higher stall and they dont have a lockup provision therefore bad for daily driving?
TH400 guys let me know what you think, i am considering going from m6 to th400.
Old 05-13-2007, 03:52 PM
FLT
FLT's Avatar
It is possible to have a lockup 400 however it is big bucks. As far as needing a higher stall because of the break that is not exactly true. The combo of having the brake with the stall will allow you to launch at a higher engine rpm. I guess depending on your cam spec's is where the tc stall selection should be. Good luck if you choose to do the TH400 swap. FLT does offer the transmission with any upgrades in which you choose if you are interested. Give Chuck a call for pricing and product info. Vince
Old 05-13-2007, 04:06 PM
Omega Doom's Avatar
I'd like to know the same question? I'd hate to pay $900 for a PT yank stall and watch the tranny let go after a little abuse especially from nitrous? if I can get the Turbo400 with stall for a little more then I might as well do that! but streetability is a main concern!
Old 05-13-2007, 11:21 PM
revtime's Avatar
In my opinion streetability with a TH400 depends entirely on your rear gear choice. I have driven my TH400 equipped 94Z with 3.73 gears and with 2.73 gears. The 2.73 gears make it almost act like a powerglide with OD. Meaning I could cruise around town using first and second and then use third on the hiway. Now with the 3.73s I was limited to about 60 on the hiway running a little over 3000 RPM. But the car was alot more fun with the 3.73s in it. I recently purchased a Strange 12 bolt with 4.10s and know with a 26 inch tire it will be running screamin RPM on the hiway. I plan on changing to a 28 inch tire to help with this.
Be honest with yourself on how you are going to use the car. Mine is not a daily driver and will see maybe 2500 miles a year on the street. I can live with 4.10s and a spool with that little of miles.
If its a daily driver you better be hardcore and have some deep pockets for gas money to have a TH400 and steep gears.
Old 05-13-2007, 11:45 PM
LS1Tech Sponsor
performabuilt's Avatar
The hydramatic 400 will take about anything you dish out , But drivable by todays standards No.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 05-13-2007, 11:47 PM
Strahley's Avatar
I drive mine around on the street all the time (on the weekends ) and it's fine, though "streetable" to me isn't the same as it is for a lot of other people. On the highway/interstate, I still get better gas mileage in my th350 LS1 than my 3.8 Grand Prix does
Mine has a 4k stall and it can pull away from a stop just fine. It's not near as bad as some people make it out to be
Old 05-13-2007, 11:59 PM
LS1Tech Sponsor
3.8 verses LS1
__________________
Call 888-744-6542
Quick Reply: Whats a streetable th400?
