th400 pan gasket?
th400 pan gasket?
I just got my th400 installed and it keeps leaking fluid. It looks like its leaking from the front of the pan. I have a cork gasket on the pan now. I just got a TCI gasket and I must say its a POS. Any suggestions on a good gasket?
leak
do you have a fill tube with an "O" ring or a boot. it may not be the gasket but the fill tube. if it leaks with the engine running it might be the pan gasket. if it leaks over night it's the "O" ring good luck jk
Originally Posted by WE TODD DID
Duraprene (spelling) gasket. It looks like thick paper.
