tranny issues???
tranny issues???
so my friend brought there grand prix over so i could take a look over it. i drove it around the block and it feels like there achor attached to the car, the only way i could really explain how it feel would be like a boost leak. i floor it and it has little power, kinda picks up from 3-4k and will not go past 4k and starts to make a clicking sound and falls on its face. i changed the fuel filter, no effect, also checked for vac. leaks, nothing??? idk what going on, cloged cat?? the car wont go past 60-70 now. i dont know where to go from here, any takers?
i just changed the fuel filter and nothing, its weird right when i start the car it takes off once but the next time i lay into it nothing. i also head it could be a bad MAF?? ill try to pop the exhaust off and see if that helps.
My girlfriend has a 99 grand prix gtp and it wont rev past 4 either in neutral. It sounds like its hitting the rev limiter. When its in gear it will go all the way to redline with no problem.
LS1Tech Sponsor
Does it sound like its skipping if so that may be the rev limiter but if it sounds like its just tops out or is strained its some other issue with the engine /fuel/exhaust etc based on all you have said I think you have a running problem not a trans issue
__________________
I used to drive a jeep. I'm pretty satisfied with the performance of its Jeep fuel filter. And it had never been my problem. But with my LS1, I just felt that I already have to change its fuel filter, it's not working well.
i'm a tech at a GM dealer, i see cloged convetrers more than once a week. you can pull the O2 sensor out before the cat and hook a pressure gauge to it. it shouldn't go any higher than 5 psi. i have only seen one transmission issue that sounds like you are talking about and it had black fluid and the worst burnt fluid smell, i'm talking worse than a normal toasted transmission. clutchs were welded together and everything.
just an FYI to everyone that doesn't know the redline is 4k in park and netural and higher in a directional gear somewhere 6-7k i beleave.
