~~How to replace 2-3 Solenoid??~~
Old 05-18-2007, 01:01 AM
spec_j's Avatar
Default ~~How to replace 2-3 Solenoid??~~
HELP ME!!!!
i need to change the 2-3 solenoid, and i DID use the search feature but the only other person that asked didnt get a reply. write up, pictures, vid, anything would be great.
Thanks in advance....
Old 05-18-2007, 06:52 AM
LS1NOVA's Avatar
Take the pan down, in the back of the valve body there are 2 identical solenoids. Just replace them both while your in there. They are only $20.
Old 05-18-2007, 12:12 PM
dknight16's Avatar
If you care, the one right next to the Fwd Accum Cover is the 1-2, the 2-3 is next in line, then the plugged accum valve bore, then the Pressure Control Solenoid. As others have said, the 1-2 Solenoid and the 2-3 Solenoid are identical part numbers.
Old 05-18-2007, 02:17 PM
spec_j's Avatar
cool, i appreciate it. I always ask before i do anything on the car so that i can have the laptop next to me as im working on the car and referance it as needed
