Any LT1 guys runing the 4l80
I have all the parts just haven't installed it waiting to do it all at once with the motor.
Built 4L80E
TCI 4L80E wiring harness
TCI flexplate
BMR transmission crossmember
4L80E Vig converter
Top Gun Spohn Driveshaft
Lokar Firewall dipstick (have yet to get this)
And some type of tranny mount
You can reuse your har lines for the tranny cooler from what I have been told.
And you have to have the Tunnel cut for the TCI controller to plug into it.
Other than the above I believe thats it.
Built 4L80E
TCI flexplate
4L80E Vig converter
Built 4L80E
TCI flexplate
4L80E Vig converter
Built 4L80E
TCI flexplate
4L80E Vig converter
what cost do you have into this ?
LS1Tech Sponsor
Originally Posted by Schurters LT1
performabuilt what do you think of the tci controller ?
__________________
Originally Posted by performabuilt
I honestly am not that familiar with the TCI controller, I havent seen any major issue with it in any of the forums I frequent.I would imagine though its probably ok . I am pretty sure the PCM is made and purchased from some other manufacturer since TCI is more of a hard parts company.
thanks
what do you think of it running just vac to control the tranny ?
can you still have a lock up TQ converter
can a T brake bee used *** well ?
thanks
Ed Wright uses the same TCI controller to control his 4L60E
Yes you can have a lock up converter and a T-brake if you wish.
Its streetable overdrive th400 basically.
You can do it cheaper but
Built 4L80E=$2300 Shipped to my door
TCI Controller=$700
TCI flexplate=Around $89.00
BMR Transmission crossmember=$180 shipped
4L80E converter=$730
Driveshaft=$440
Dipstick= $75
Total=$4514
Built 4L80E
TCI flexplate
4L80E Vig converter
Cost?
TCI flexplate
4L80E Vig converter
Cost?
TCI Controller=$700
Driveshaft=$440
Dipstick= $75
Total=$4514
Have any of you seen the kit for Camaro's that this sponsor sells? http://speed-eng.com/store/index.php?cPath=23_940_1409
I don't see the kit on the site now but I KNOW they had it???
I think I'm going to give it a shot too. I was going to do a TH400, but I wanted to be able to have fun on a highway. I'll probably go with a low mileage stock 4L80E, add a full manual kit, and a decent converter and fab the rest to work.
-Dustin-
-Dustin-
TCI Controller=$700
Driveshaft=$440
Dipstick= $75
Total=$4514
TCI Controller=$700
Driveshaft=$440
Dipstick= $75
Total=$4514
Also did you have the cover plate on the converter custom made to fit this flexplate? Which Vigilante did you go with?
I am doing a budget Full Manual 4L80E and the only items left to figure out is the converter and the flexplate.
Thanks.
-Dustin-
TCI Controller=$700
Driveshaft=$440
Dipstick= $75
Total=$4514
TCI Controller=$700
Driveshaft=$440
Dipstick= $75
Total=$4514
I got mine done about a month ago. I went with a Vigilante from Tbyrne. I got it custom made for a LT1 flexplate and it ended up running me 629.
The install was pretty straight forward compared to what I had imagined. I fabricated my own trans crossmember by welding steel to extend it [The 4L80E sits back far] I could have bought the BMR or Yank one, but it saved me $200. I also run Transgo's Stage 3 Full Manual Valve body kit, which eliminated the very expensive controller and wiring issues. I kept lockup which is just a matter of rigging up a switch to the power and TCC tabs on the trans plug. I bought 1/4" NPT to barb fittings to clear the tunnel and ran rubber tranny line to the cooler. It's very hard to make the stock shifter work due to the angles of the shift level, so I put a B&M Mega shifter in, which fit perfectly with the TH400/TH350 shift cable bracket. It just bolted right on. I also run a deep pan and got the driveshaft shortened an inch or so, and I was all set. Thankfully I got the trans yoke with the trans which helped getting the driveshaft mated correctly.
So thats what I did...
4L80E $100
Transgo $250
Driveshaft $100
3200 Vigilante $629
Total $1079
Options
Derale Deep Pan - $80
B&M Mega Shifter - Traded two old tires
Pretty good deal considering I spent $2000 on a 4L60E that blew up going 25mph.
-Dustin-
4L80E $100
Transgo $250
Driveshaft $100
3200 Vigilante $629
Total $1079
Options
-Dustin-
4L80E $100
Transgo $250
Driveshaft $100
3200 Vigilante $629
Total $1079
Options
-Dustin-
4L80E $100
Transgo $250
Driveshaft $100
3200 Vigilante $629
Total $1079
Options
-Dustin-
