Swapping in a 350
Swapping in a 350
I am swapping in a RMVB t-brake 350 and wonder who you guys reccomend for:
RMVB
T-brake
driveshaft
torque arm (needs changed correct?)
crossmember
shifter (will be using m6 console)
RMVB
T-brake
driveshaft
crossmember
Rossler for the transmission.
Dennys for the driveshaft
BMR for the torque arm
BMR for the crossmember
B&M for the shifter
If you want to keep a stock length TA BMR makes a great conversion crossmember that relocates the TA. If you go this route you could actually use the stock TA if you wanted.
I run a B&M Pro Stick shifter. Simple, cheap, and effective.
B&M for the shifter
I run a Coan 4000 stall and I like it alot. Its pretty tight for cruising around (this is relative, its still a loose stall) but zings right to 4k when I hit it.
I am just south of Olathe, suburb of Kansas City.
Ive got a TH350 in my car and you wont have to buy a new driveshaft bc the stock one can be used.. Unless your just wanting to buy one..
Also BMR makes the Crossmember you need and if you get the one with the Torque arm reloc. on it then you can use your stock torque arm.
As for the shifter you can use your stock console and just cut out the center of it so it makes room for your shifter and then just paint the console and you will never know the difference .
TH350: i bought mine off ebay and it already came with everything (EX. Tbrake, RMVB, all HD clutches, FUlly built) --$985 Brand new.
Torque converter: Bought mine from PTC out of Alabama
SHifter: Hurst Pistol Grip.
Thats all i needed for my swap.
