New trans rebuild - No 3rd or 4th gear!
I had about 200 miles on a new built trans. Coming home today from a good day of tuning - I lost 3rd and 4th gear. Manual low and 2nd work perfect. D and OD work fine until it hits 3rd gear and then it revs up with no power.
There were not any weird signs of failure before it happened, i just floorboarded it @ 70 mph and it bouned off the limiter. Its been F'd ever since.
I built the trans myself - everything was 100% inspected, clearances checked, seals replaced...etc.
Here are the parts that were replaced/upgraded:
-HD rear 5 pinion planetary
-vette 2nd gear servo
-sonnax super 4th
-alto kolene steels
-alto red eagle clutches
-alto wide band
-transgo **** kit
-10 vane pump rotor gear, guides, and vanes
-beast sun shell
-sonnax 1-2 and 3-4 "pinless" billet accumulators
-TCI deep pan
I have a hard time believing/thinking that its the 3-4 clutchpack but with my luck it probably is. The fluid still looks new and pink!
I haven't torn it down yet but I was hoping someone might have an idea or could point me in the right direction...
Thanks,
David
-sonnax super 4th
-alto kolene steels
-alto wide band
-transgo **** kit
-beast sun shell
-TCI deep pan
Thanks,
David
It is possible that you might have broken the input drum where the 3-4 clutch snap ring is suppose to go. This can be caused by excessive pressure, improper accumulation or even feed hole sizes that are much to large. I guess the first hing to do is to see what is damaged first and then figure why. Good luck, Vince.
my trans does the samething, check the 3-4 clutches and make sure they are all good before you put everything back together just to be on the safe side. Doesnt take alot ot mess them up once the car free revs
Yep... 3-4 clutchpack is TOAST.... Everything else looks perfect.
I noticed when I was pulling the snap ring out that there was a TON of slop in the drum. I'm assuming its because all of the clutch material is gone? Maybe I F'd something up during install. Can anyone recommend anything I should check and inspect?
Can I purchase just the 3-4 clutches and steels? Should I replace the steels?
Please take a look at the link below - its a pic of my "new" clutches
http://www.terratraction.com/incoming/DSC03267.JPG
Thanks,
David
Thanks,
David
I would have thought I messed up a lip seal while assembling but everything looks good. What else can I inspect that would cause loss of pressure to the 3-4 clutches?
