1st gear AND overdrive issue - need help
okay so i installed my 4l60e trans last week and everything was fine. today i took the car to work and after a little while on the highway, i got to my exit, stopped and when the light turned green i had no first gear. i got up to speed and noticed that my overdrive didn't kick in...
i took the car to lunch - and everything was fine...
what gives??? does this sound familiar to anyone?
okay - i do have a check engine light on - but i can't check them anytime soon (at work).
autozone pulls codes for free - would their scanners be able to tell me trans codes???
what is limp mode???
thanks for the quick reply
code p0757 - "shift solenoid stuck open"
says possible cause are poor electrical connection, low fluid level, or failed shift solenoid.
i just did the install, so i know the fluid level is right... and i think all my electrical connections are good.
so that kinda leaves me with a failed shift solenoid. what do you think???
A solenoid is a very likely cause for this code in a fresh rebuild if the solenoid was not replaced. They are not difficult to replace at all, could be done inside an hour.
Is the converter a recent addition? It could cause similar problems.
g
g
