How do you remove the 4l60e pump?
Old 06-11-2007, 05:04 PM
66 chevy truck man's Avatar
Default How do you remove the 4l60e pump?
Ok let me start at the begining I had the TQ managment taken out of the computer and the tranny decided to stop pumping. The tranny only had 5k on it too. The fluid looks perfect and no debris in the tranny so I think I should be ok to just replace or rebuild the pump. I pulled the tranny this weekend and now I just need to know how to remove the pump so I can rebuild it. Any of you guys done this? Any help would be appreciated.
Old 06-11-2007, 05:15 PM
Predator T/A's Avatar
take off the pan remove the tccc soleniod and then remove the pump bolts and you can use a screwdriver in between the reverse drum and the back of the pump and pry it out if you dont have a pump puller....pretty simple
Old 06-11-2007, 05:16 PM
make sure not to pry against the thin parts of the case like where you can see the pressure regulator and the filter port you may break the case...ask me how i know lol
Old 06-11-2007, 07:32 PM
Montec's Avatar
yes dont pry too hard against the case or the pump, they are aluminum and WILL distort, causing leaks.
Quick Reply: How do you remove the 4l60e pump?
