94 Camaro with LS1/TH400 which trans mount?
Old 06-13-2007, 02:14 PM
Z06kern's Avatar
Default 94 Camaro with LS1/TH400 which trans mount?
I have a 94 LT1 Z28 Camaro that I'm building into drag race car. I'm putting a LS1 in it along with an TH400 trans. I'm looking at the BMR conversion th400 trans mounts. Which one do I need? The ls1 version or the Lt1? From the pictures on thier website it looks like the mounting holes and mount design are completly different between the two. I thought the frames from 93-02 where basically the same.
Old 06-14-2007, 08:40 AM
Z06kern's Avatar
Since nobody responded the mount I needed was the LT1 version. The bolt hole pattern on the floor pans are what is different.
Old 08-12-2007, 01:47 PM
SERIALPIMP's Avatar
Demonpixel on here is doing something similar,
yall should talk
Quick Reply: 94 Camaro with LS1/TH400 which trans mount?
