No OD after rebuild
No OD after rebuild
Had my C5 trans rebuild by a good shop. Trans came back and I reinstalled.
During test drive I find that I don't have 4th and the car doesn't engine brake. The computer has not set any codes. Any thoughts?
Mike V
Mike V
Originally Posted by performabuilt
first I would look at the data stream to see if the PCM is comanding the 4th shift. When you say no engine braking do you mean in the lower gears d&3 2 1 or in the OD 4th position
Thanks for the help.
Mike V
LS1Tech Sponsor
Originally Posted by Jordan S.
I think he's talking about when he manually shifts it into a lower gear the gears dont pull the rpm's down ?
As for why wouldnt it comand the 4th shift thats hard to say but in any diagnosis of a no upshift or really any shifting issue the first thing is to look and see what the PCM is telling the trans to do.
__________________
At 50 to 60 mph you probably wont feel a brake effect . If you have an available scan tool you can watch data to see if it is comanding 4th gear at all . The band is on in 2cd and 4th but applied through a different circuit and a different part of the band servo . I would check the servo !!
