Problem with 4L60E build
I have a Express van with a 4L60E in it. I rebuilt the transmission, then went through the Rocky Mountains. It generated the slipping code just after that. I made it home, and lost second gear less than 15 miles later.
I got the DVD from Technical Video, and noticed it mentions checking for binding of the 2-4 band by rotating the output shaft both directions. I couldn't rotate but one direction, even without the 2-4 band. I had my son double check both sprags for proper operation, and had him look over my shoulder while I built it all back up. I still can turn the output only one direction. This is the same as the first rebuild.
Do I have a problem, or is the video mistaken or leaving something out?
Are you trying to yurn it by hand or with channelocks or pliars . You may only be able to turn it one way by hand , the other way you are turning the entire geartrain and there will be a lot more resistance !!!!
Since the video showed turning the shaft with one hand, I thought that is the kind of resistance I would meet also. I was turning it by hand. I could twist enough to lift the transmission off the table, but it felt like it was locked up solid. I'll try the pliers tonight.
Well ,I tried a set of water pump pliers on the splines. I think the pliers are around 2 feet long. It turned both ways fairly easily. It's amazing what a little leverage can do.
I'll stick it in the van tomorrow and let you know how it goes.
