Hp tuners Line Pressure
I have a 2000 Formula A4 and I am trying to figure out want line pressure I should run, I read the sticky above and I dont't think it applies to HP turners. Because I have the line pressure set at 90% and it shifts extremely hard, the max is 96%. ON the HP turners program I did the performance shitft and it shifts at 90% 1-2, 2-3, 3-4 so if any one could help me to figure out what line pressure I can run safetly that would be great.
well when i put mine in i wanted harder shifts and was told to not put it above 90, currently i have set to 90,which is what it comes with oem, and it does not shift hard but could be cuz of the converter. it could be shifting hard if you maf is disconnected or not working. chek on the trans diagnostic section. max line pressure dtc they should be set to dissabled. also on our cars performance shift does not work unless you set up some wires on the pcm. i just set the same values for normal cruise and hot.
