Where do i put in temp sensors for gauges
i am going to run an trans temp gauge and a oil temp gauge
where can i and or how do i get them to be put somewhere.
pics would help
but any info
thanks
pics would help
but any info
thanks
Transmission temp guage sender should be located in the pan.
Engine oil temp should be near the filter area...I think. Send a p.m. to "1970 Judge" at Xtereme Horsepower, he'll know.
g
g
Originally Posted by GregWS6&z28
pressure port on driver side of trans. temp is close to pan temp and sender is direct fit
Yeah this location works very well and as stated its a direct fit!!
TAwhore, are you using their single or dual version Interceptor? If it hadn't been for the high price $239/$399 a lot more people would have installed it in their vehicles.
Are you using it for anything else besides just the temp read-outs?
sorry for hijacking...
i'm using a single gauge...it can display to parameters at once
i'm using it for: IAT, MPG, Coolant Temp. Tranny temp. fuel lvl.
other uses that i haven't used yet (some i hopefully won't need) obd2 diagonstics, 1/4 mile performance, misfires, maf signals, LFT, SFT ect.
basicly eveything a obd2 can scan for on any car
also you could hook up a wide band or boost sensor to the little thing.
not to bad for 200 bucks or so
Originally Posted by performabuilt
The Pan is the ideal spot to get a good average temp . The presure port can be used to but the temp may appear a bit higher than it is I have seen 20 degrees difference between those two positions.
