HD3 and Converter lock up
Old 06-28-2007, 08:22 PM
formula355LT1's Avatar
Default HD3 and Converter lock up
I'm having my trans rebuilt and getting the Trans Go HD3 manual valve body kit. Am i going to have problems locking the converter up? If so how do i get it to lock up normaly? Its a 95 OBD1. also im going from a 2600 stall to a 4400 stall anything else i'll have problems with? THANKS
Old 06-28-2007, 08:27 PM
Gilbert@Ace Racing's Avatar
No! Having installed several TG HD-3 kits myself I can say that if installed correctly the manual features will not interfere with L/U at all!
You might have issues with L/U timing because of the converter stall speed. But look me up if it is not right after you get it running because it could easily be just fine.
g
Old 06-28-2007, 08:52 PM
thanks, by lock up timing do u mean at what MPH the converter will lock?
Old 06-28-2007, 09:28 PM
LS1Tech Sponsor
performabuilt's Avatar
I know the HD3 make the 4l60e and full manual VB trans with no need or use for electronics, So im not sure how the lockup would work unless you somehow reprogramed the PCM to ignore all other functions of the trans and just lockup at some preset throttle and MPH. Of course if your using it in a non A4 car I am not sure how you would do it other than a switch or something.
But personally though I have read the instructions I have never personally installed the HD3 only the SK and the HD2 kits in a 4l60E. I have done the full manual 700r4 many times however.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 06-28-2007, 09:34 PM
Yes, that's what I have in mind. Keep me in the loop.
As you may know already, when going to a higher stall sometimes the TPS and MPH do not agree in the current L/U tables. If so then those tables may need to be adjusted.
g
Old 07-29-2007, 10:00 PM
ok trans is in with HD3 hooked up and everything and my converter is NOT locking up at any speed in any gear... the converter i went with is TCI part # 243100 and the place i bought it from says its a lock up converter.
Old 07-29-2007, 11:14 PM
FLT
FLT's Avatar
I will have to look at the directions tomorrow. I do know if you are not running a computer you will need to wire up the tcc solenoid in the pump with a manual switch.
Old 07-29-2007, 11:50 PM
What PCM system are you running? Factory or aftermarket? And did you plug in the Electrical connector on the transmission as it sill requires the input from the PCM in order to engage the converter clutch.
g
Old 07-30-2007, 09:45 PM
stock tuned PCM, everything is pluged in to the trans
Old 07-30-2007, 09:47 PM
Shouldn't be a problem at all. It will retain proper lock up functions.
g
Old 07-30-2007, 11:05 PM
Dynojet Fan
VH5150's Avatar
how do you like the HD3??? i wanna do it too
Old 07-31-2007, 11:03 AM
Get a scanner on it and determine if the lock up function is being commanded.... just reread this thread and realized LU is inop.
g
Old 07-31-2007, 07:23 PM
I like it a lot i feel like im in more control of the car while driving around, i think the HD3 would be funner with a smaller stall though.
Quick Reply: HD3 and Converter lock up
