1-2 shifts when hot
1-2 shifts when hot
I just got my tranny rebuilt with all the upgrades wide bands servos transgo shiftkit and other stuff. my problem is when the car gets hot the 1-2 shifts just bounces of the limiter i dont know what would be causing this i had my computer tuned by pcm4less for the 3000 stall and i dont know if the shift points were moved or not but i dont recall on having them moved with the car having a stock motor. so i wonder what can cause this problem it is a 95 lt1 car as well.
If indeed it is a tuning issue you should have your pcm tuned by someoned familiar with those symptoms. It should be data logged in order to determine whether or not the shift command is being issued and when is it being issued.... only then can adjustments begin to be made with any hope for success in a few tries.
Good Luck.
g
Good Luck.
g
