4L80 f-body guys PLEASE COME IN
Old 07-11-2007, 04:01 PM
02402RAMAIR's Avatar
Default 4L80 f-body guys PLEASE COME IN
I am doing a M6 to 4L80 in a 2002 f-body
how did you get your ECM to control the 4L80?
Old 07-11-2007, 10:31 PM
spy2520's Avatar
just in case you didnt see it:
Originally Posted by Z'mnypit
~ The PCM "WILL" control the 4l80e. Ive seen this alot on here where people say you have to buy a standalone contoler from TCI. If you want to go that route then thats fine but the stock PCM will control the 4l80e. You will have to have the PCM flashed with a new operating system. I simply pulled the .hpt or .bin file from my car, emailed it to Keith at HPtuners and he fixed it to reflect the new OS to control the 4l80e. You can have EFIlive do this also, but you, yourself can not make these changes.
~ 98 PCM's will not control the 4l80e. There are a couple alternatives for 98's. You could run a manual valve body meaning you shift gears yourself. Or you can control the 4l80e either with a TCI stand alone controller or the BS3. The BS3 has a module where you can contol any GM trans just like you would with HPtuners, EFIlive, or LS1edit. You could also swap out the PCM for a 99+ PCM then have the OS changed. (thanks obZidian!)
doesnt exactly tell you but it is a little info...
Old 07-11-2007, 10:39 PM
I have been trying to get hp to do this.
I have not had any luck.
after many e-mails I am still no closer to getting a bin. file.
