c5 transmission solution
I just finshed my rebuild and put a 2800 stall on the car as well. I have heard the stall will add a lot of heat to the transmission and I have learned very quickly on here that 9 of 10 tranny failures are due to heat. I do not want to put a tranny cooler on the car so i was wondering if this was a good solution. I was planning on putting a 160* thermostat on. The tranny fluid runs throught the radiator to cool off so if the coolant is always cooler, it should help cool the tranny as well correct?
Input appreciated.
Input appreciated.
There are coolers made that are "stacked" with a built in fan that can be controled automaticaly or with a switch that can be mounted in an area that doesn't have to have normal airflow !!!
