m6-4l80e swap (shifter problems)
Old 07-13-2007, 04:52 PM
ttcamaro's Avatar
Default m6-4l80e swap (shifter problems)
I pulled a shifter and cable from a 02 camaro with a v6. I bought a lever and bracket for the 4l80e to mount it. I dont know if the v6 cables are different but the stupid thing is too short. when i pull to shift down from park it doesnt work. when the shifter is in first theres no way it will ever connect to the lever.
thoughts? V6 cable to short?I mounted the cable on the side of the trans where the plug goes in. Did i do something wrong?
Old 07-13-2007, 08:24 PM
ttcamaro's Avatar
when swapping your 4l60 to a 4l80 are you using the stock shifter cable, lever, mounting bracket?
Old 07-15-2007, 09:31 PM
02402RAMAIR's Avatar
I am doing a M6 to 4l80 right now
https://ls1tech.com/forums/southern-members/748119-m6-4l80-swap.html
