What did I break, Converter or Transmission?
Location: Somewhere Between Mild Insanity and Complete Psychosis
Originally Posted by Will82
Heading home, came to a stoplight. Left the light casually at green, and the car revved to 3000rpm before shifting at 25mph or so. Hmmm. Car ran fine on the 2.5 hour freeway trip home, at speeds of 90mph when possible. Tranny temps steady at 194 degrees, car shifted into 3rd and 4th gear fine after slow-downs and re-acceleration. Even at city speeds, no problem. But anytime I go under 15mph or come to a complete stop and the re-accelerate, the motor revs all the way to 3000rpm at low speeds before shifting around 25mph or so, which makes me look like quite the jack-***.
Originally Posted by performabuilt
Do you have all the gears ?
On that note, do you have experience building c5 converters and transmissions? I know the c5 converter is different from f-bodys, not sure about the transmission though. Would the pricing be the same?
Thanks.
i had the same symptoms as you when i lost second. the car would drive fine up to 15-20 and then it would like rev up like in neutral before it shifted again. still drove it for awhile and then i lost 3rd as well, and then the car would never shift out of first. installed a built tranny/converter and everything has been fine
LS1Tech Sponsor
How is the trans doing ?
__________________
