polythane tranny mount
pretty easy to install. can i do this myself or do i have to grab
a friend to come over.. any advise. thanks guys. stock 02 z28 a/4
It's Pretty Easy Not That Hard! For The First Hundred Or So Miles Your Tranny Is Going Feel Harsh While Driving It You Will Feel The Difference From Stock Ruber To Poly But After It Breaks In The Harsh Will Go Away!
Easy job, just make sure the car is high enough. If you have ramps only, try putting rear tires on the ramps. It gave me a little more room to work, due to the rear suspension being a little higher than the front.
