Trans mount
Old 07-24-2007, 07:41 PM
Enforcerws6's Avatar
Default Trans mount
I am putting a tunnel mounted tq arm on along with a ton of other things. Would putting a stock type mount back on make the car less vibration happy. I wouldnt think a standard mount would break near as easy now since the force that cracks them is gone. I have a poly mount on now and the car picked up a ton more road vibration with it.
Old 07-24-2007, 07:47 PM
LS1Tech Sponsor
performabuilt's Avatar
Yes it will reduce vibration considerably has been my experince. I dont much like the poly mounts for that reason
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 07-24-2007, 08:56 PM
spy2520's Avatar
i never really had vibration issues with my poly trans mount, seems it can go either way though.
Old 07-25-2007, 05:49 PM
zrater's Avatar
any notice at all after install and you drove it.. thanks
Old 07-26-2007, 10:14 PM
Well I had the crappy dreaded steel out of balance pos drive shaft up until now so it shook bad. Having 4.11 in the rear and an auto meant at normal highways speeds the car vibrated terrible. Hopefully the new pst alum shaft will cure most of that but i may still go to a standard trans mount now that the tq arm is off the trans. I know i will likely get some vibration thru the tunnel mounted arm but I hope its no where near as bad as it was before.
