4L80-E - made a boo boo :-(
Hi there!
Quite a while ago I overhauled my 4L80-E, had a rebuild kit and used almost everything in it. It went fine afterwards... with the exception that the transmission overheats after 30 minutes or so, the oil pan gets as warm as a stoveplate.
Now I've decided to have a look at it again; this far I've only started the car, removed the hose at the oil cooler to see if there's any flow, and indeed it is - with the gear in D it'd probably empty itself in less than 30 seconds. Now I'm not sure what to check next.
I'd be very happy for any thoughts regarding this.
