I want to convert from M6 to Turbo 400, can I use any Turbo 400?
Turbo Addict
Whether it came out of a truck or car changes things but i think you can use any of them.
I have a truck tranny w/4" tailshaft (also has lower 1st gear) so I needed to have my yoke machined and my driveshaft had to longer than stock length. I was able to use the stock T56 crossmember w/o modifying it. I think with the 9" tailshaft housing you can use a stock length driveshaft with a standard Th400/4L80E Yoke. Depending on your header set-up you may have to cut the ears off the tranny...I didn't have to because I'm turbo.
I have a truck tranny w/4" tailshaft (also has lower 1st gear) .
Al
