shifting problem......
i have a 99 camaro with a 2500 stall automatic, and shift kit. the car has 77000 miles. i just had the trans flushed and filter changed, now the 1-2 shift is feeling like its sliding into gear, and the 2-3 shift is hitting rev limiter and wont **** till i let off. it NEVER did this befor i had the trans flushed, HELP..........any help?
make sure the tranny has the proper level in it the machine is suppoed to replace what it take out but i have seen it not work right.....was the fluid dark or black before it was flushed?
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
i check the fluid level and its good. the tranny shop said there was no metal flakes or shavings, and they said the fluid was dirty, but they said everything looked ok.
like i said before this was done the tranny was on the money and shifted great.
with high milage trannies its a gamble to have them flushed what happens is the valvebody gets worn out and with the old fluid and varnish in them it keeps the shift valves sealed and fills in the gap made by the wear but when you change the fluid and flush it out it takes all the varnish away and then you have leaking valves it happens alot after a flush at the dealer i worked at we wouldnt flush dirty fluid or black fluid we were not even allowed to recommend it unless it was due by manufacturer recomendations to cover our own asses lol
__________________
very good possibility....you may be able to change a valvebody at this point and it may help it but it is a gamble.
__________________
you may want to check out our website for your application I would recomend the level 2 however if you have plans for modding it I would go with the level 3
__________________
The level 2 will be good we have level2 trannies running in the 10s but there is always room to grow with the level3
__________________
i have had the same prob with my car occasionaly when i drive for no reason it will hit rev limiter and wont get off it till i let off the gas it only hapens between second and third but i am scared to see what a rebuilt trany would cost does anybody know how much it would b
Depending on what Level unit we are talking about you are looking somewhere around $2000.00 for the transmission. I am thinking a Level 2, but do not really know your combination at all.
g
g
nassa blue you can check out our website and call we will be happy to help you with your needs right now we have the level 3 transmissions on sale take a look and ls1adam same for you right now the level 3s are on sale priced very close to the level 2s
__________________
are those prices for a rebuild kit, or a complete transmission?
ALSO......i have called other tranny shops and they are saying that if the shop put in the wrong type of filter it could cause this problem. is this possible? and i dont understand how the car was shifting just fine with NO PROBLEMS and now it dont shift right, there is noway something could have broken, im never going to a shop again.
yes they did change the filter but the part number they gave me for the filter is for a generic filter and i was told it was for an older z28, what is the pcs? they draind the fluid from the torque converter also. this is a dang mess.
it is inside the pan on the VB it will be a round black cylinder looking thing with with a 2 prong plug it will be behind the 1-2 accum housing it has a 8mm head bolt retaining it
__________________
