want to see ratchet shifters installed
#41
If anyone is interested in keeping the stock A4 shifter I was able to modify mine to work with a RMVB. I pulled the shifter and modifyed the gate so that it locks into 2nd gear then to switch to 3rd you push the button. I also welded in a stop so that after 3rd gear it won't go any farther back since I use a TH400. I love it and I didn't have to hack up my console because I still use the stock shifter. If anyone is interested and has any questions let me know.
#42
Can you use a round shift ****, possibly the same one as stock on a b&m hammer shifter? or are u stuck with the t-handle?
I have a ss **** from ws6store i would want to put on there.
whats the part number on the Hammer shifter?
This shifter will work with a 4l60e?
#43
quicksilver with a 3 spd.
im about to lose my stock look. bout to move to a glide and wont be able to use the shifter anymore.
i do not want the ratchet shifter look.
i have kept my car stock appealing.
anyone have pics of the black stealth pro ratchet?
at least it wont be all bling in there.
keep it black and toned down.
#46
nothing special, just get in there and hack until the console fits down nicely.
i had one M6 top i had to cut in the front. i cracked that one and have another one in the car currently, so the console may require trimming as well.
could be a year/mold difference.
air body saw works great. dremel, grinder. it all does the job.
#47
Have you installed this into your car?
Gonna sell it since your going to a glide?
#48
thats about the only pic i have.
i did weld tabs onto the shifter, so it bolts right in with factory bolts where the stock auto shifter use to reside.
i already have a sale lined up if i go to a glide.... but its not looking good unless i want to build a set of headers.
what i have is all in the way of the linkage for the shifter.
since its a shifter thread, anyone have pics of a powerglide pan with the shifter linkage hooked up?
#56
the hurst promatic is available in a glide version.
from their online catalog, operation is the same.
i need to call them and ask demensions vs a quicksilver, so i can keep my 6 spd look. if not its time to figure out something new.
#57
i have a quicksilver setup now, and wont be able to use it with my powerglide.
#58
he did not have exact deminsions.
S&W racecars come to mind. when you call those guys, they will email you a build sheet, or give you a measurement within .060" usually.
if all goes well, i may have one of these shifters by mid november and can report back a realistic fitment.
#59
Hi guys
my brother owns a 96 Z28 Camaro and he has been trying to find out if he can fit a B&M ratchet shifter to his 4L60E (auto) ?
Looking on ebay and on other sites we have not found any for the 4th gens.
Could anyone help us
Thanks
David
Thanks
David
#60
I don't have any pics at the moment, but used a B&M Mega shifter ratchet shifter in my 04 goat. it is listed for mid 80's Camero....not listed for the 4l60e, but I did a little cutting and welding on the bracket s for the cable mount and shift lever on the tranny.....works great
