Help TH350
Old 08-10-2007, 04:55 PM
01blackformula's Avatar
Default Help TH350
I need how to use my stock shifter over again after I install the TH350. I was told by many people that it can be done it just has some custom work you have to do to it. Does anyone now how to do this?
Matt
Old 08-11-2007, 10:07 PM
anyone?
Old 08-11-2007, 11:38 PM
LS1Tech Sponsor
performabuilt's Avatar
If you just bolt it up it should work , Your lettering will be off
OD=D
D=2nd
2=1st
1=you cant move the shifter to there
You may have to play with the bracket mounting on the trans to get the positions correct. FYI drill some new holes in bracket . I would put the trans in park then the shifter in park then figure out where the bracket needs to mount to put it there.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 08-12-2007, 12:05 AM
matt94z's Avatar
OD=D
D=2nd
2=1st
That's what I did and it works great.
Old 08-13-2007, 02:30 PM
thanks alot guys I will try this and it will save me about $1000.
Matt
Old 08-13-2007, 02:36 PM
smoknta's Avatar
Matt
How would you save a $1000? , thats a very expensive shifter.
Old 08-14-2007, 04:30 AM
matt94z's Avatar
You can get a nice shifter for $150-$250 depending on what you want.
Old 08-17-2007, 08:28 PM
Because if I couldnt do the shifter then I would have to get somebody to put it in that knew what they are doing, and they were all going to charge me at least a $1000 to put it in.
Old 08-17-2007, 08:29 PM
I want to keep the stock look.
