Where's the T-brake located on a th400
Old 08-19-2007, 03:58 PM
98turbls1's Avatar
Default Where's the T-brake located on a th400
Just like the title says... I'm wondering which solenoid is the right one to tap into... Also, what are most of you guys using to activate them... I have a prostick and amy thinking of getting the ball with the button on top... Thanks in advance...
Old 08-19-2007, 04:12 PM
lethal93ta's Avatar
mines all internal, it uses the stock kickdown terminal for the brake.
I have a B&M hammer with a diffrent handle on it with a button
Old 08-19-2007, 06:58 PM
98turbls1's Avatar
Is it the one that is on the left side right above the shifter linkage mounts..
Old 08-19-2007, 07:11 PM
FLT
FLT's Avatar
That is a pass through connector. If you have means of taking a picture and posting a picture, you will get an answer much quicker. Most quality brakes use the modulator circuit which is located on the passenger side of the case. I have seen a few that are internal solenoids. A picture will help us as far as where they are located in the transmission and how they work. If you do not have means of doing this, I will look to see if I have or can find some pic's for you. This will help us give you better information on what exactly you have. Vince
Old 08-19-2007, 07:18 PM
98turbls1's Avatar
Old 08-19-2007, 07:28 PM
lethal93ta's Avatar
thats where mine is on mine but some have solenoids that are mounted on the passanger side like Vince stated
Old 08-19-2007, 08:21 PM
FLT
FLT's Avatar
Originally Posted by 98turbls1
Do you have any pic's of the other side of that trans. By the way that converter is a nice piece. I have a Nomad that is a record holder running one of those. How much did it cost you?
Old 08-19-2007, 08:27 PM
98turbls1's Avatar
I paid $1125 for it shipped to my house from Neal... I can't wait to actually use the damn thing... It's pissing me off that it's taking this long... JW was back ordered so it should be coming in shortly but I'm also waiting on a BMR crossmember.... Waiting for parts is what's taking most of the time...
I'll try to search for some more pics of the other side... Thanks for your help...
Old 08-19-2007, 08:37 PM
98turbls1's Avatar
Here's the right side... I didn't see any solenoids on that side though...
Old 08-19-2007, 08:53 PM
lethal93ta's Avatar
a vaccum port on a manual valve body? Im no trans guy Ive never worked on them thats why I had mine built but I thought all that got pulled when you put a manual body in there. I know its all pulled off of mine and plugged.
Old 08-19-2007, 09:02 PM
98turbls1's Avatar
You know I'm no trans guy either... I should find out in a week and if it's not then I've traveling up to Chi town and kicking some ***... =)
Old 08-19-2007, 09:07 PM
lethal93ta's Avatar
one of these guys will be able to tell you.
Old 08-19-2007, 09:09 PM
FLT
FLT's Avatar
98turbls1 by the looks of that picture if you have a break it must be using the pass through connector on the drivers side. You might want to contact who built this unit to see if this unit in fact is a break unit. Normally the vac mod is not used or has a plug like the other member has posted. If you have any pic's of the internal pan area this would help me. Vince
Old 08-19-2007, 09:11 PM
FLT
FLT's Avatar
Where did you get this trans?
Old 08-20-2007, 09:06 AM
98turbls1's Avatar
I bought it from a guy on racingjunk... I'll take a pic of when I get it down to put a JW bellhousing on it... If for some odd reason it doesn't have the RMVB how labor intensive is it and how much would the "average" shop charge for it??? If you don't want to throw out quotes please pm me...
Old 08-20-2007, 09:31 AM
jakeshoe's Avatar
Almost all TH400 brakes are RMPVB and most use the solenoid in place of the modulator.
I know of one that uses an internal brake and also one that retains normal forward pattern automatic operation.
Old 08-20-2007, 04:16 PM
lethal93ta's Avatar
when I had my trans built they only charged me 200 more to put the brake in mine, if I would have done it after the build they wanted 900 to put it in there after, they said they would have to pull the whole trans apart again, something about drilling the case, like I said Im no trans guy thats what the shop told me when I had mine built.
Old 08-22-2007, 03:59 AM
revtime's Avatar
My Rossler has the T brake solenoid where the vac mod is in your picture.
Old 08-22-2007, 09:14 AM
98turbls1's Avatar
Are there any RMVB (non-tbrake) that people don't take out the vac modulator???
Old 08-22-2007, 09:38 AM
408z28's Avatar
no, if its rmvb its not an automatic valve body. Therefore eliminating the vaccume modulator. Vaccume modulators are for forward automatic shifting valvebodys.
Quick Reply: Where's the T-brake located on a th400
