Trans Temp Guage Needed after Stall?
Old 08-20-2007, 10:27 PM
CAMAROZ28AQUINO's Avatar
Default Trans Temp Guage Needed after Stall?
Ordering TCI 3000 stall tomorrow, just wondering if i need to have a tranny temp guage or should i not worry. Daily driver, sees around 250 miles every month.
Old 08-20-2007, 11:04 PM
Strahley's Avatar
As long as you have a nice big cooler in a good location, I don't see the *need* for a trans temp gauge. I don't use one, and haven't had a "blowing up due to heat" problem on my th350
Old 08-21-2007, 01:45 AM
bmxer8699's Avatar
nah, wouldnt bother with one. even gilbert told me its not that big of a deal for a small stall thats a DDer. as long as its not a full out drag car youll be fine.
Old 08-21-2007, 05:35 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Its not needed but a tranny gauge will not hurt anything either.
Old 08-21-2007, 06:07 AM
g-ryde1's Avatar
not really needed but one gauge (ie A/F) in a gauge pod just looks so lonely
Old 08-22-2007, 01:51 AM
98LS1auto's Avatar
Well I like to know the temp of my motor and the temp of my tranny. When you spend over $2000 on a tranny to me its cheap piece of mind. JMO
Old 08-22-2007, 03:41 AM
revtime's Avatar
I agree. If you monitor your engine temps and it gets too hot you shut it down to prevent engine damage. Same deal with an expensive trans. If it gets too hot you will know it and can save the tranny.
Old 08-23-2007, 11:28 AM
Blacker's Avatar
I race mine once in awhile and the trans temp gauge is my indicator of when to stop. Granted, the gauge is not really needed and I think too many gauges looks bad. In the TA, the AC vents are a perfect place to install a 2 5/8 gauge and I put one in. Most of the time, my temps are below 180 and the gauge is more visual. At the track, once I am over 200 degrees time to shut it down.
