Will I need a tune with a PT4000?
Old 08-21-2007, 12:55 PM
BeachZ's Avatar
Default Will I need a tune with a PT4000?
Hi guys,
I'm having a Yank PT4000 installed. Will I need a tune afterwards?
Thanks.
Old 08-21-2007, 01:25 PM
Ragtop 99's Avatar
Sometimes you need to adjust shift points or delete a code. It is not a certainty nor do you need a full tune.
Old 08-21-2007, 02:46 PM
BeachZ's Avatar
Thanks. The reason I asked is because the car is not idling well at all.
Old 08-21-2007, 02:58 PM
Ragtop 99's Avatar
Did you do an idle reset? On a cold motor, pull PCM fuses, let it sit 15 minutes. Restart and allow the car to fully warm -up and relearn the idle. You go between park and gear a few times and that normally does it.
If that doesn't do it, you may need a little more idle air. A 1/2 turn (open) on the idle set screw is normally enough to fix that and not mess up the rest of the tune.
Old 08-21-2007, 03:01 PM
BeachZ's Avatar
No, I didn't. I just picked it up this AM on the way to work, and it wasn't fun. Stalled a few times in LA traffic.
Thanks much. I'm sure the reset will take care of the problem.
Old 08-21-2007, 08:23 PM
AutomagicLS1's Avatar
You might need a tune. Mine did some crazy stuff it wouldput my car into limp mode all kinds of stuff. it is a brutal converter though on the street
Old 08-22-2007, 11:28 AM
BeachZ's Avatar
Amen to that. The 4000 replaces a 3400 stall, and the difference is like night and day.
