Help me pick a stall
Old 08-27-2007, 01:48 PM
its turbo time's Avatar
Default Help me pick a stall
With the mods i have in my sig what should i pick, I drive the car a lot as it is my DD, and i run a 100 dry shot at the track. I searched a little bit and read that the nitrous affects how big of a stall you wanna go, but i couldn't figure out how much it does affect it and which way you should go if you've got the gas (higher or lower).
Also how much does the stall hurt the mileage?
thanks
Old 08-27-2007, 02:31 PM
Omega Doom's Avatar
I would say either a Yank or Vigilante 3200-3600 would be perfecto!
Old 08-27-2007, 04:37 PM
LS1Tech Sponsor
performabuilt's Avatar
Though the ones above would be fine. I would suggest one of ours inthe 3500 to 3800 range. And While I cannot speak for the converters above low end economey will only suffer a little but cruising speeds should stay the same as they are now. Perhaps wih the lower mass of the converter just a little better
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 08-27-2007, 05:50 PM
Sunny's Avatar
I have had the Yank SS3600 in my DD for the last year and a half.
It is a great converter; it slips less than my TCI 3000 Street Fighter did.
With MTs on stock 16“ rims I get 1.7 60’ and 8.2 1/8 times.
My car is basically stock.
Old 08-27-2007, 05:56 PM
sunny...how did that convertor affect your mileage?
Old 08-27-2007, 05:59 PM
Websy21's Avatar
go atleast 3200 to 3600, I love mine but would probably even go bigger next time. Mine is a DD and love it
Old 08-27-2007, 08:06 PM
koolaid_kid's Avatar
I lost 1-2 mpg in the city. On the road, it will be the same because you will be in lock up mode. Think about it, and you will understand.
Hope this helps.
Old 08-28-2007, 06:49 AM
Omega Doom's Avatar
I have a Yank 4200 and it's awesome!
